Centre speaker position
Discussion in 'Home Cinema Speakers' started by Sprocket, Dec 10, 2004.
  1. Sprocket
    Sprocket
    I'm new to all this but have now spent 3 nights learning loads off this site - thanks!
    quick question -is the centre speaker best placed above the tv or below ?
  2. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Both work as well as each other in my experience but underneath the tv can look better. As long as the speaker is magnetically shielded it doesn't really matter.
    Mylo :)
  3. Sprocket
    Sprocket
    Ok thanks
    Yes it is shielded but as tv and speaker are to be built into eaves space of an upstairs room it will look ok either way but I have to decide before cutting the hole in the wall!
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    As mylo says, both work reasonably well. Apparently below works best but I've never had a chance to try it myself. I would expect your seating position to be more important, that is that the centre speaker should be roughly in line with your forward pair and that the tweeters of that should be around your normal ear level.
    In my opinion personal preference and how it fits in the room is more important than exactly where the best acoustic position is (which varies between each room and layout I'm afraid). :)
  5. Dean
    Dean
    Jun 20, 2003
    2,894
    London
    +265
    In the furure if you get a wall hanging display or projector you should put it on a dedicated stand, tightens up the sound remarkably.
