Centre speaker placement issues
Discussion in 'Home Cinema Building DIY' started by devag, Apr 9, 2017.
  1. devag
    devag
    May 21, 2016
    47
    11
    UK
    I currently have my centre speaker above my TV, which as you can see in the attached photo when placed above the TV, it is not aligned with the front left and right tweeters.
    I ideally want the centre below the TV as shown in the image, but for this to happen I need to up the TV a bit. I was thinking about putting the TV on the wall with a bracket, but that is kind of defeating the purpose of having my TV unit and the viewing position of the TV from the listener would be slightly to high.
    ive been looking around on google etc to try and find something that would make it possible to keep my TV on the unit, with some sort of riser (which doesnt look ridiculous). Does anyone have any ideas or any other different solutions that may work?
    thanks
  2. raoulx
    raoulx
    Feb 4, 2011
    329
    2
    Lancaster
    +80
    For me the to unit is to put things in or on. I'd put the telly on the wall as suggested it doesn't have to be high, maybe a couple inches above the centre.
    There is options though where you can rise the tv up, I'm pretty sure @gibbsy (I think that's something like his username here) has something like that if I recall correctly? Basically a matching wooden piece to his unit which is a 3 sided box which goes over the centre speaker with enough space for the TVs stand to go on.
    I sort of had the same issue but rather than buying a new av cabinet I fit things behind the wall buying an av blaster so it could be the tv and speakers
  3. barry7767
    barry7767
    Sep 19, 2007
    573
    +416
    You can get replacement universal stands, some of which have height adjustment. Depends on your TV mounting points etc, but something like this may give enough clearance?
    Stealth Mounts SM-17 TV Stands
  4. gibbsy
    gibbsy
    May 17, 2007
    12,698
    3
    Cwm Cynon, De Cymru
    +6,905
    Yes. Had it from HiFi Racks. Very good colour match for my oak cabinet.
  5. devag
    devag
    May 21, 2016
    47
    11
    UK
    yeah nice alternative. cheers guys
