Centre speaker - On top or under TV? (I've got a 36" Pixel Plus on it's stand) (nt)
Discussion in 'Home Cinema Speakers' started by PapAV, Mar 27, 2003.
  1. PapAV
    PapAV
    May 10, 2002
    187
    +15
    t
  2. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Try both and see which you prefer :). I have mine under the TV as the distance from ear height is less than it would be if on top.
  3. General Skanky
    General Skanky
    Jul 28, 2000
    4,208
    71
    +43
    I was about to go with the ear height bit, but also gonna add, that it also needs to be relative to where the picture is. Ie, as close to where the pic is as possible also. Locking dialogue to screen and all that.
  4. Dave H
    Dave H
    Aug 20, 2000
    4,374
    Lots of different places!
    +145
    The center speaker should be near as dam it level with the main speakers for the best effect you don't have to worry about being slightly forward or behind because you just adjust the center deley slightly to compensate.
    cheers Dave.
