Calzor Suzay
Do any companies sell stands/shelves that will sit on/clip to a Plasma tv so you can place a centre speaker on top of it?
I have no place for a centre so bought an amp that directs it through left and right when it needs which i was sceptical about but works a treat 4.1![]()
The speaker is a B&W CC6 S2 so a fair old size. In the end I used two metal cavity wall fixings, an old AV stand board as a shelf between wall and top of TV and rested it on that with some block fixings to stop it sliding forward.
Hopefully it'll still be there tomorrowCost £0
Spod,
It's probably a bit late but I needed to wall mount a similar sized speaker and these were just the job.
http://www.av4home.co.uk/acatalog/AV4-BT15-Centre-Speaker-Wall-Mount.html
