Centre Speaker leakage
Discussion in 'Home Cinema Speakers' started by MartinImber, Feb 1, 2004.
  1. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    My centre speaker causes some disturbance on the screen eg during Matrix Ch29 at over half volume.
    How can I improve magnetic shielding?
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,090
    notts.
    +64
    Hi Martin
    Is it colour staining or the picture distorting my monitor audio centre used to make the picture wobble at the edges when turned up to high volumes try isolating with thicker blu tack did help slightly.
    Cheers Gonzo.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Picture wobbling along the top
    I put some balsa between which helped a little
    However the speaker has grown a load of paper weights and a clock.
    I might try some rubber or foam strip then.
    No colours out - so you think it is vibration based?
    Mainly noticable with 2.35:1
  4. alexs2
    alexs2
    Nov 13, 2002
    13,957
    +1,671
    The only effective way,short of adding shielding around the magnets inside,is to add distance between the speaker and the TV,and remember that the damage can be very difficult to rectify if exposure isnt reduced quickly.
    My previous Linns(Keltiks,and not shielded)could distort the picture on a CRT at 1 metre...blutak and balsa wont attenuate magnetic activity other than by increasing distance.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I don't know if it is magnetic or vibration!
  6. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    If it's magnetic the image will likely show large areas tinted green or red. It literally looks as if the image is being dragged towards the speaker.
    From what you've described (wobbling picture, and improvements by isolating the speaker) it's probably due to vibrations.
    Have the speaker on as you usually would, and lift it just so the feet are off where it usually rests (so you're taking the weight, but not increasing the distance). This should eliminate any vibration interference, giving you the definitive answer to come back here for more advice with :)
  7. hazard
    hazard
    Apr 24, 2002
    137
    Cork
    +3
    You might like to invest in a centre speaker stand.
    Go to www.cpc.co.uk and search for "ST0074566"
    It is cheap enough to try anyway.
  8. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Get some ear plugs too. Holding a speaker in front of your face during Chapter 29 is very brave! :eek: :D
  9. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    A mouse mat seemed to fix it:clap:
