Centre Speaker - Is A shelf Bad ?
Discussion in 'Home Cinema Speakers' started by GForce, Jan 9, 2004.
  1. GForce
    GForce
    Hi All
    Im planning on getting 6 Kef Q1's, 5 on Stands ( Atacam Nexus 6 ) but im strugling with the front centre.
    Ive got a Tosh 32ZD26P TV and cant stand the speaker ontop or underneith - As usuall the TV is in a corner ( Hence 6.1 Setup ).
    If i mounted a Centre speaker on a corner shelf will it ruin the effect ? I guess it might boom a bit and as it would be approx 0.8 of a meter behind the two fronts id need to adjust the delays ?
    Any Advice or other sugestions either for mounting or Setting it up ?
    Thanks for your help
    Kind Regards
    Gareth
  2. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
  3. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    I've used centre speakers on wall mounted stands - no problem, just use a SPL meter to check volume afterwards
  4. GForce
    GForce
    Mylo your a Star
    Thats exactly what i need !!!! I was thinking of maybe making somethin glike this but though it might look a bit rough - This one looks great - less chance of boominess aswell :)
    Cheers :) This forum rules :smashin:
    Regards
    G
    ( Cheers for replying aswell common - much appreciated - at £7 the farnell one is probably cheaper than a wall bracket and should sound better ( maybe - well less setting up ) )
  5. Digger
    Digger
    Dec 31, 2003
    4,204
    World Wide Supermarket
    +206
    I' ve used with great success Ikea's tv wall mount £9 for fronts and rears as well placing the speakers horizontally, its very rigid with up to 7 screws for fixing - not forgetting a few blobs of blu-tac
    regards
  6. scarfie
    scarfie
    Feb 25, 2002
    48
    I'll second that, I've got the same centre CC350 and just bought a new Thomson which couldn't fit it - until now. Good on ya!
