Centre Speaker for B&W set-up
Discussion in 'Home Cinema Speakers' started by RohanM, Sep 17, 2004.
  1. RohanM
    RohanM
    Jun 4, 2004
    365
    London
    +37
    Have 603S2's for the front (as currently used in my stereo set-up), with an older pair of 601S1's for the back (they were my previous speakers, which were lent to a friend when I upgraded to the floorstanders, but have now been returned).
    Got a Denon 3805 on order - demo'd it using the above set-up (but with the current versions, i.e. S3's) with an LCR60 for the centre and REL Q150E sub. Was going to buy that centre, but then discovered that my Panasonic 36PD30 telly's stand will not accommodate it... :eek: The shelves are just under 7" high, the LCR60 is just over 7"...
    Now, do I get the B&W centre from the DM300(?) range, or the VM1 (which is aesthetically better)? I can't find a dealer who has both in stock for me to demo.
    Alternatively, which other brands would match sonically AND fit in the stand? :lease:
  2. digisocialist
    digisocialist
    Sep 5, 2004
    480
    Yorkshire
    If it were me, I'd forget compromising your speaker choice to fit the stand and buy a new stand. You have over a grands worth of speaker there...
    I don't know what the TV stand looks like but can you get spacer bars to put between shelves? Or add on shelves which you could mod with steel bars to get the extra 1" in height?
  3. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    or put speaker on top of tv
  4. Mark123
    Mark123
    Sep 20, 2003
    454
    Belfast
    +29
    I agree with digisocialist. You have a great speaker set up there - I would be reluctant to compromise on your centre speaker. I would definitely look into the options for a new stand. I have a similar set up to yourself, but have the LCR600 centre.
  5. mick23
    mick23
    Mar 20, 2002
    801
    uk
    rohanm cant you just remove one shelf from tv stand??? i had to do this with my toshiba tv stand my lcr60 sits on top of my vcr ,but i use 4 plastic feet to protect speaker and vcr , these came supplied with my bw600s2 speakers.
  6. sparky1
    sparky1
    Feb 22, 2004
    782
    28
    southampton
    +34
  7. RohanM
    RohanM
    Jun 4, 2004
    365
    London
    +37
    Hmmm, hadn't thought of that! Mind you, as I don't think that resting my DVD player on the LCR60 is a Good Idea (maybe I could search for a sorbothane platform?), and as the rest of the AV kit (amp, CD player, etc) sit on an Atacama stand which is approx 2-3m away, I'd have to move the DVD player (which is a DVD Recorder) and ntl STB to that. Which means another 3m of component cable, plus long SCART plus... I'll go do the maths!
    Is the LCR3 (which is the smaller B&W centre) that much inferior?
  8. Ridcully
    Ridcully
    Feb 16, 2002
    356
    28
    +35
    As you have 603S2 why not use a CC6 S2 as this is around 6".
