Centre Speaker - Flat or Upright - Any Difference
Discussion in 'Home Cinema Speakers' started by leshall, Jan 4, 2007.
  1. leshall
    leshall
    Jul 26, 2006
    351
    London
    Does it make any difference if the centre speaker is stood up instead of laid flat as most people seem to do.The speaker has a central tweeter with a woofer either side.Is their a problem with this set up.Any disadvantage sonically.
    Thanks in advance.
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    Try it and see.
  3. fourfoot
    fourfoot
    Mar 12, 2006
    187
    Central London
    +11
    Shouldn't make any difference.
    Most people just put them flat because it's more convenient. All the center speakers I've had came with removable feet so you could have them either way up.
  4. stevos
    stevos
    May 16, 2004
    6,179
    +580
    Historically all centre speakers where just a single main speaker i.e. a stood up rectagle.
    However as av took off, people wanted a more pratical approach because having a tall speaker on top of the tele looks a bit stupid and so the horizontal speaker was bourne.
    To answer your question either way should work fine, however to ensure the best sound all your main speakers tweaters should ideally be at the same level but it isn't that important.
  5. stevos
    stevos
    May 16, 2004
    6,179
    +580
    p.s. if they aren't the best way around it is to ensure that all the tweaters hit your listening position at the same height and to angle the centre as required to ensure this and then adjust the distance measurements within the av amp.
  6. leshall
    leshall
    Jul 26, 2006
    351
    London
    Thanks for all the info supplied.Much appreciated.:thumbsup: :smashin:
  7. leshall
    leshall
    Jul 26, 2006
    351
    London
    Mods please close.Have the info I need.:thumbsup:
