centre speaker advice needed.
Discussion in 'Home Cinema Speakers' started by addo106, Mar 22, 2006.
  1. addo106
    addo106
    Jan 27, 2006
    350
    Poole, Dorset
    +17
    hi i've just got a new av rack (2 ikea oppli's) and my centre speaker doesnt fit in the gap 44cm x 25cm. i am looking for just a centre speaker that will fit in the gap, stay about the same price as the other speakers and sounds good!
    speaker also needs to be beech in colour
    my current speakers are all missions
    M72, M7C1, 70DS, M70as
    any suggestions welcome. thanks in advance :lease:
  2. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    So you need a smaller mission or need to change the fronts as well...
    So beyond pointing out the obvious I can't really help :rolleyes:
    MK make a small centre (can't remember the range- they're all small).
  3. addo106
    addo106
    Jan 27, 2006
    350
    Poole, Dorset
    +17
    hi just looking at replacing the centre so the new one will fit on the shelf. thanks will have a look at the mk. seen a mission M3C2 which they do in beech which would fit
  4. mhuk05
    mhuk05
    Jan 17, 2005
    2,721
    J6 M5
    +214
    The MK one is about £250. If there's a Mission that fits it'll probably be a better fit sonically. How "good" it is...?
  5. addo106
    addo106
    Jan 27, 2006
    350
    Poole, Dorset
    +17
    £250 is too much only looking too pay about £50-100 and will probably try and pick something up 2nd hand on the forum or flea bay
  6. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    Much cheaper to drill new holes for the pegs for the two vertical pieces so you get a wider centre area. Shouldn't take too long.
  7. addo106
    addo106
    Jan 27, 2006
    350
    Poole, Dorset
    +17
    yeah i think i am gonna do something to fit it in because i am perfectly happy with it and don;t really want to spend £100 changing it. if i made the middle section bigger i couldnt get av equipment either side and also as i have one on top of the other (opplis) it may look a bit weird. cheers for the reply
  8. Jammyb
    Jammyb
    Feb 5, 2006
    4,029
    Coventry
    +576
    If you do that can you let us know how you get on and maybe post a picture of what it looks like?
    I'd like to try this as I'm fedup of my Ruark centre crushing my TV.
