Centre Speaker Adjustable Speaker Spikes
MacReady
I have become more aware over the last few Months of a few times when the sound from my centre speaker seems a little 'boomier' on vocals. Not sure if that's the best way to describe it but it just doesn't have quite the same level of clarity as my front L/R speakers sometimes. (Speakers are Dali Opticon at the front)
I wondered if it was because it is sat on some small rubber feet on top of the AV unit...which is an IKEA unit with a glass top? Could isolating the speaker more from this unit help with the clarity?
With this in mind I started looking at stick on spike feet with shoes for centre but I thought it would also be a good idea to try and angle the speaker a little towards the listening position with shorter spikes at the back? This would also raise it up a little as well which surely couldn't hurt?
So, am I on the right track trying to do this and, if so, can anyone recommend some adjustable spike feet/shoes that can be stuck on the speaker and allow me to have a lower height at the back please?
Jase
Angling the centre speaker towards your head height is generally a good move. Not sure if spikes would be much benefit over just getting a couple of taller rubber feet for the front of the speaker.
As mentioned, you'd also need spike shoes/discs so that you don't damage your AV cabinet.
Out of curiosity what crossover do you have set for the Centre?
MacReady
I have to be honest in that I thought spikes may look better than rubber feet as well ;)
I have the crossover set at 80Hz on all speakers across the front soundstage.
Jase
Rubber doesn't look pretty but does the job nicely. With spikes I'd probably make sure the shoes/discs had a rubber base rather than have metal on top of the AV stand surface. Avoids any slippage etc.
Might be worth trying a slightly higher crossover for the Centre. 90hz or 100hz could be enough to take away a bit of boom.
MacReady
Thanks, will give the crossover setting a try (watching Spectre again later in our run up to No Time To Die at the cinema tomorrow, so will be a good test to see if it improves it)
mjbtin
Is the centre right at the front of the av unit?If set back soundwaves reflected of the top of the unit can cause boominess and reduce clarity.
Worth a try if not already at the front.
Martin
MacReady
Martin
It's about an inch away from the front of the unit....so not too far back.
I tried changing the crossover as well and have watched a couple of movies with it at 90hz and 100hz. I am honestly not sure if it's just the placebo effect making me think it sounds better, but it does seem to have lost a bit of the roominess!
I still want to get something to raise it from the top of the cabinet more and angle it at the MLP though.
Gasp3621
Definitely use the whole height you have available so the center channel comes just below tv. There is table stands and you can DIY one too or buy the two "feets" to wall mount the speaker below tv, although i would always prefer speaker more in to room than against wall unless designed to be used on-wall. First thing to do is to get it higher and closer to where your main speakers tweeters are. Some ribbon tweeters have limited vertical dispersion so even more important to get them at seated ear height, at least closer and then tilting upwards. Higher crossover setting can work better as we have seen countless times.
Amazon product
Amazon product
These look bit low:
Amazon product
mjbtin
Derek S-H
Many people seem to have their Centre speakers at knee height when sitting down!
I appreciate that it's very difficult to find AV cabinets that can accommodate placing Centre speakers high up so they're closer to the level of the Fronts.
Looking at your picture, I think the SoundXtra tilting stand that @mjbtin linked would be perfect to give a try, especially as it's only £25. I use their stands for my Atmos upfiring speakers and they're heavy, solid and work well.
There's an Allen key adjustment hidden inside under the badge on the side that allows you to tighten them sufficiently so they don't drop in use. Angling your Centre up might make a big difference to the sound.
You might also consider one of these to put under your Centre to isolate it from the AV cabinet:
Dimensions are 40 cm x 30 cm.
So put the chopping board on the cabinet, then the tilting stand on top. Angle it towards you and lock off using an Allen key.
Good luck!
unoduo
I used 3 or 4 of these self adhesive feet stuck together to place under the front of my centre speaker to slightly adjust the angle. They increased the clarity of my centre and ensured a better timbre match with the mains.
Cheap (well cheaper) than chips too. They surprisingly look quite aesthetically pleasing.
Dobbyisfree
Did you adjust the crossover in the Audyssey app then resend calibration to the AVR? This should get better results than adjusting it on the AVR.
MacReady
No, have to admit I didn't..just changed on the AVR. Will do as you suggest though and change via the app.
I have been looking at a few different stands and options to raise the centre up higher, including all the ones suggested above. I am going to make a decision on which will look and work best and get something ordered this week...will post on here once I have an update and to confirm if it has improved the sound. Thanks everyone.
Derek S-H
Feel free to add a pic or two!:)
