Centre speaker above projector screen
Discussion in 'Home Cinema Speakers' started by SanPedro, Jan 9, 2004.
  1. SanPedro
    SanPedro
    Jan 11, 2001
    4,528
    +511
    I have a 7ft + wide opening into a conservatory which I think would be an ideal place to house a projector screen. It has double doors to it and I was thinking of fitting heavy curtains to block light from the doors and window area in the opening and fitting the screen to the top underside of the opening - Its the thickness of the outer wall about 10" thick.
    My question is: will a centre speaker be ok placed above the PJ screen. i can't place it under the screen as this will obviously block entry to and from the conservatory.
    Chris
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    So long as it's well accounted for in setup, I can't forsee too many problems.
    It might be ideal to angle it toward your listening position, but this could prove difficult.
