Centre Speaker - Above or Below the TV?
Discussion in 'Home Cinema Speakers' started by ReVeReNcE, Dec 23, 2003.
  1. ReVeReNcE
    ReVeReNcE
    I'm looking at building a cabinet/stand for my TV and other bits & pieces and was considering a shelf for the centre speaker to sit on. I am going to buy a Monitor Audio Bronze centre (to match the fronts), but am undecided as to whether it would be better above or below the tv).
    If it were placed on a shelf on the rack below the TV, it would be about 40-45cm high. The other option is having it on a shelf above the TV, but I think this would be too high (about 1.6-1.8m high). Don't really want to put it on top of the actual set, so which position would be better?
    Thanks :cool:
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    which position is the best compromise of close to the screen and close to your ear level? whichever one it is, thats the best for your centre. I suspect that is probably below
    ad
  3. mjn
    mjn
    May 24, 2001
    21,874
    Herts, England
    +9,558
    have mine below
  4. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Slightly angle the speaker, so it points directly to ear level at your seating position.......nice custom shelf maybe?
  5. chris
    chris
    Nov 20, 2000
    1,226
    romney marsh, kent, uk
    +28
    I got mine on a shelf above the TV.
    Slightly agled down by about 10 degrees so it looks like the sound is coming from the TV and not above.
    If you have it below the TV then maybe you could angle it up........dont think it really matters where you have it, as long as you give it a slight bit of angle....not to much thow......you dont want them talking from the celling, or the floor.
  6. ReVeReNcE
    ReVeReNcE
    Thanks for the replies. Below will probably be most practical, should be able to angle it up as suggested. Will post some pics of it when (and if) I make it!
