centre rear flat speakers?
Discussion in 'Home Cinema Speakers' started by Suki, Apr 22, 2001.
  1. Suki
    Suki
    Any suggestions - I am just about to upgrade to 5.1 from 6.1 and want to buy a single speaker rather than a pair .
    I can only get my wife to buy in to the idea if I get a discrete one that looks like a picture so was thinking of a flat panel speaker ( mission? ).
    Any suggestions of speakers or dealers.
    The other speakers in my set up are B/W 602s and cc6 up front,Canon V100s as the rear pair and rel q100 sub.
  2. Guest
    Have you considered an in wall speaker from the B+W range? (Assuming you have a stud wall) :)
  3. robocop
    robocop
    Oct 16, 2000
    648
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    Try talking her into a Mission m7c1 center speaker.
    I managed to talk mine into it and it only cost £85.
    It may not be as discrete as a picture speaker, but it has a narrow profile.
    check out Mission on www.mission.co.uk
