Centre matching recommendations?
forestfan
My systems is as follows:
Marantz SR4200
Marantz DV4100 ose
Mission 77ds
TDL G30 rtl Floor standers fronts
Iam trying to Match a centre with a budget of £150 - £200 with the TDLs has anyone got and suggestions.
As TDL gone bust and for some reason one of them will not produce any sound ( and tested) without any warning any repairer recommendations or suggestions for replacements for the fronts I need to use as music and av sources all roled into one.
Thankyou
B
bob007
A little over your budget @ £235 but staying with the Mission surrounds you all ready have you could go for the Mission M73's, these are floorstanders and are very good with music and movies, then probably the Mission M7c2 centre. ;)
forestfan
Cheers bob,
Thankyou for your recommendations as for my budget of £150-£200 that would be for the centre, so the M7c2 fit in as for the fronts I would still prefer them to be repaired however I have a budget of £200 - £300 I will test the mission M73 s.
B
bob007
I you have no luck with the repair then your budget of £200-£300 will get you a pair of M74's.
forestfan
Cheers to both bob and slowhand for the advice and link, just had a mate round to look at the speakers and managed to get the other one working so I think I will audition the M7c2
