Centre Cable Choice
Discussion in 'AV Receivers & Amplifiers' started by powder40, Mar 6, 2003.
  1. powder40
    powder40
    To do justice to the Pioneer AX 10 amp what cables are worth looking at when connecting it to a good quality centre speaker (my centre is the ProAc CC1 ).
  2. eddiea
    eddiea
  3. CounterWhine
    CounterWhine
    Jul 1, 2002
    1,480
    63
    Oxford
    +155
    I use Kimber 4VS at the moment. I want to recable my home cinema eventually. The obvious choice for me would be Kimber 8TC but I'm tempted to try Nordost Solar Wind assuming it's available in monowire form.
    D.
  4. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    defo a case of law of diminishing return imho.
    once you get to "bloody good" cable e.g. qed silver anniversary, then you're tailing off on improvement per pound very quickly - set yourself a budget and find what sound right to you.
  5. eddiea
    eddiea
    I have Silver anniversary on my surrounds, however I've tried some on my fronts (Monitor Audio Gold Ref) and the speakers don't sound anything like they do with the Cord Odyssey. :D
  6. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    wasn't citing qed as the be all and end all - it' more a case of finding what is good and what you can afford - there is no guarantee that nordost cable will sound signicantly (if at all) better than a considerably cheaper cable. Try b4 you buy
  7. eddiea
    eddiea
    Correct;)
  8. Lowrider
    Lowrider
    I use the same as the fronts... it would be too expensive for the surrounds, otherwise it would be the right choice too...
  9. graxxor
    graxxor
    60A Ring Mains Cable and contact enhancer... Can't beat it for current handling... ;)
    Oh, except by biwiring it of course.
    Note, the word RING... Trying to bend this stuff into any other shape requires a pair of pliers.
    It really does sound good (to me) and is really cheap, even triwired... :laugh:
