Centre and Subwoofer
Discussion in 'Subwoofers' started by aqureshi, Mar 25, 2002.
  1. aqureshi
    aqureshi
    Can someone advise me which one is the best Centre speaker out of the following:
    Eltax HT2, Mission 70C1, Celestion F35C
    I am also thinking of buying a cheap Subwoofer and wonder if any of the followings are any good:
    Celestion S80, Yamaha YSTSW205, Mssion 70AS and Tannoy max sub 10.
    Asad
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    The "best" center is the one which matches your fronts ... :)
  3. aqureshi
    aqureshi
    Thanks Reiner,
    My Fronts are Silverstone 110. My room is a normal size so any recommendation from the list.
    asad
  4. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    You forgot the Paradigm Ps 1000 :D
  5. aqureshi
    aqureshi
    Yes u r correct that I forgot PS1000.
    Are u recommending this one?
  6. lynx
    lynx
    Jan 20, 2002
    4,652
    It always rains.
    +302
    No mate.It was supposed to be a humourous remark as you have enquired about this sub in few other threads nd ironiclly it was the only one ommited here. :)
