Central Heating System Power Flush price?
Discussion in 'General Chat' started by Deadringers, Dec 18, 2016.
Tags:
  1. Deadringers
    Deadringers
    Jul 14, 2008
    9,833
    Herts
    +1,800
    Hey all,
    Looks like we need to get our system flushed as we have a couple cold spots and areas on our radiators.
    I'm getting quoted 450 for 6 Radiators - 2 bed Flat.
    That's including VAT.
    Now this company does come highly recommended, has been around for quite a bit and guarantees that the system will be clear for 5 years.
    From plumbers and others who know about these things, does this sound good to you?
    From doing research online it seems perhaps slightly on the high side (50-100 more than some would expect).
    BUT - A big concern of mine is that this isn't just a company that half arses this, I want something that will last.
    Reason for that is that the last time this system was flushed was 2010 and it's already showing these signs. (previous owner).
  2. IronGiant
    IronGiant
    Jun 7, 2003
    65,954
    +45,964
    Some of the cheaper quotes you've seen might be as part of a new boiler install?
  3. Deadringers
    Deadringers
    Jul 14, 2008
    9,833
    Herts
    +1,800
    Oh really?
    So you feel that for the size of my place 450 is okay?
  4. IronGiant
    IronGiant
    Jun 7, 2003
    65,954
    +45,964
    No, I'm horrified at that price :( Just trying to think of a reason why prices differ so much.
  5. Arcam_boy
    Arcam_boy
    Jun 13, 2006
    12,006
    2
    Birmingham
    +2,354
  6. McVicar
    McVicar
    Mar 31, 2015
    5,874
    163
    It's funny you should ask that...
    +8,258
  7. IronGiant
    IronGiant
    Jun 7, 2003
    65,954
    +45,964
    Ouch...
    Data from 2014.
  8. McVicar
    McVicar
    Mar 31, 2015
    5,874
    163
    +8,258
    How old is the boiler, how many rads are affected?
  9. Wahreo
    Wahreo
    Oct 11, 2012
    15,343
    +12,528
    As with all of these things, if you don't like the price then simply do it yourself.
  10. IronGiant
    IronGiant
    Jun 7, 2003
    65,954
    +45,964
    As in take the radiators off or hire a power flushing machine? I've got a dead radiator and I'm probably just going to take it off the wall and give it a damn good thrashing Basil Fawlty style.
  11. MrSossidge
    MrSossidge
    Jan 7, 2006
    6,373
    East Riding of Yorkshire
    +5,434
    I've taken a couple of radiators off in my old house before. Took them outside and bodged a hose in them with the rad upside down and waited until the water ran clear. Takes a while but did the job.
    I've just been quoted a power flush at £360 + Vat for the same house which I now rent out as the bathroom rad was cold even though it was bled. I got someone else to go and look and they replaced the valve for £70 and that did the trick.
    I have also texted my plumber today about 4 of my downstairs rads as they are hot at top and cold/warm at the bottom. He has said they may need balancing but is coming tomorrow and if not I will ask him how much to powerflush.
  12. Wahreo
    Wahreo
    Oct 11, 2012
    15,343
    +12,528
    Take them off and get the hosepipe on them and then whack them with a rubber mallet.
    Personally I'd hire a powerflush machine and then use the chemicals but I am able to do it. If you can't then you have to cough up and pay someone.
    Remember, it's not just the cost of doing the job, that's probably only worth £300 but the rest of the cost is knowing how to do the job.
  13. McVicar
    McVicar
    Mar 31, 2015
    5,874
    163
    +8,258
    Was it a TRV valve? I had the same problem with a rad and my guy told me to unscrew the TRV valve which exposed a small basic pin underneath. Small pair of pliers gripping it then up down up down up down with the pin which freed it up, back on with the valve head et voila. In my case it was simply that the pin had set in its lowest position and wouldn't rise
  14. MrSossidge
    MrSossidge
    Jan 7, 2006
    6,373
    +5,434
    No, it was a valve on a chromed towel radiator.
  15. richardb70
    richardb70
    Mar 2, 2005
    5,202
    Reading
    +2,386
    Does it have to be a powerflush, or simply a full drain down and refill? If it's the latter then it's fairly easy to do yourself if you have the time / inclination. You just need a decent length of hose pipe and a bottle of the chems from B&Q or Screwfix. I did this at my last house, worked a treat. I avoided a powerflush as this can cause problems with old radiators.
  16. wilbanat
    wilbanat
    Sep 25, 2009
    7,668
    +9,541
    My neighbours heating packed up a few weeks, they called out a plumber and he got it working of sorts, charged £180 for this and then explained that they needed a power flush and gave them the quote to do this....Ready ? ..................£1100+VAT :eek:
    I nearly spat my drink out when they told me, not a big house at all and would all be done in a day.
    I urged her to get other quotes but she don't do that sort of thing and promptly whipped out her cheque book.
    The prices above in the thread don't sound that bad to me but this was just taking the P :thumbsdow
  17. Ruperts slippers
    Ruperts slippers
    Dec 18, 2004
    8,234
    Earth
    +4,234
    I charge between £150-£800 for a power-flush, depends on the type of system, combi's are easier than open vented for instance, 15mm-35mm easier than micro-bore, copper better than plastic. Old rads have more potential problems than new rads, sole trader will be cheaper than a larger company, man with a signed up new van will be more expensive than a chap with a banger..
    Guy with a Kamco machine will charge more than the bloke with a hose pipe and some BQ chems etc, etc..
    Distance to job, access, parking, site issues such as access to bolier, rad or pump, access to drain and mains all affect the price.
    There are plenty of trades, if you don't think the price given represents good value, either find another who does or do it yourself.
  18. MrSossidge
    MrSossidge
    Jan 7, 2006
    6,373
    +5,434
    Plumbers been. Balanced the system and didn't suggest Power Flush at all so didn't get a price.
  19. Deadringers
    Deadringers
    Jul 14, 2008
    9,833
    Herts
    +1,800
    I think a few people here think that I think the price is too high.
    I don't think it's too high/a rip off, I'm just trying to do my due diligence to ensure it's a fair price (as I have no idea!)
    Thanks all for the feed back. - sounds like I'm on the right track.
    @neilios Yes these people seem to have all the proper stuff - Kamco Machine, PH levels before and after, 5 year guarantee on their work etc etc.
  20. AbandonedTrolly
    AbandonedTrolly
    Nov 24, 2016
    43
    Location, Location
    +41
    Hi my Mum had to get one of these done and sorry to say, she paid between 600 and 700 quid. That was Scottish Gas, property is coming up for 20 years old (1997) so as such so is the boiler.
  21. Deadringers
    Deadringers
    Jul 14, 2008
    9,833
    Herts
    +1,800
    That does sound quite high - unless she has a big house?
  22. AbandonedTrolly
    AbandonedTrolly
    Nov 24, 2016
    43
    Location, Location
    +41
    No infact she only has a small 2 bedroom house up and downstairs, but i think the issue was the house builder failed to put the solution into the system to prevent rusting so as such there was mountains of crap inside the pipes which had to come out
  23. Deadringers
    Deadringers
    Jul 14, 2008
    9,833
    Herts
    +1,800
    Ouch that sounds bad :(
  24. AbandonedTrolly
    AbandonedTrolly
    Nov 24, 2016
    43
    Location, Location
    +41
    Yeah flaming Persimmon Homes, useless.
  25. hippy240980
    hippy240980
    Jan 25, 2011
    969
    96
    Glasgow
    +1,108
    This thread resurection reminded my to clean out my Magna Filter.
    A while ago i got a new boiler with a flush and afterwards, i had a couple of old radiators with cold spots. I just replaced them with new ones, since i was taking them off anyway, and less hastle than cleaning them out and "maybe" would work after that.
    I was going to clean out the filter before winter hits and this thread has reminded me to do that!
  26. Tempest
    Tempest
    Jan 11, 2002
    8,234
    Horley, Surrey
    +3,720
    Apologies if this is a stupid question ;)
    People are speaking of power flushing and cold spots or dead rads.
    Ok, let's put dead rad to one side as that's a bit obvious.
    But what exactly would you describe as a cold spot which would be cured by power washing?
    If you have older rads, which are thicker steel, as I understand it, they will take longer to fully heat up to "OMG if I touch it, it hurts" temperature.
    Heat / hot water rises so the top of the rads will get warmer than the bottom, likewise I guess the middle of the bottom will be the last to get up to temp?
    How long for the whole rad to get all up to the same temp, with a old thick steel rad would be considered normal?
    Probably hard to answer as depends on the size of the rad, and one of mine is about 2.5m long!
    I guess I'm just trying to get an idea of what is just normal, and expected, as these things all take a while to fully get up to temp, and what would genuinely be considered a cold spot, which would be fixed by flushing.
