Centon 500mm MC Mirror Lens Compatibility
djm07
Hi all,
I've just got a quick question regarding the Centon MC 500mm Mirror Lens. I believe it is a Minolta fit and fitted a Centon DF 300. I'm just wondering if this could fit a DSLR with an adapter for the SLR, e.g. a canon, or nikon adapter and would it work?
Thanks again
shotokan101
shotokan101
It's currently going for £16.99 with 21 hours left and 11 watchers, fingers crossed for a bidding war :D I've got a minolta mount, but the canon's go for over £50 :thumbsdow
Good luck then - do you mean centons in cannon fit ?
My two are M42 fit so I use an adapter on the sony....
Jim
djm07
Jim
I've got no clue when it comes to lenses, but it probably is, the cap at the bottom was canon branded from the ebay picture. And thanks, if it reaches £20 I'll be chuffed, anything else is a bonus
shotokan101
...might sell mine yet then :devil:
JIm
