CenterStage CS-1
Discussion in 'Plasma TVs' started by Rob100, Jan 7, 2003.
  1. Rob100
    Rob100
    Nov 3, 2002
    3,468
    +227
    According to the spec it can take an interlaced "RGB or YPrPb" signal.
    Now I know this unit is from the USA, so when they say RGB do they mean RGB as we know it?? What I am really asking is if a JS RGB-Component box would be required to connect lets say a Sky box to the CS-1?
    Thanks,
    Rob.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    13,983
    +2,788
    The last few days I had cs-1 on appraisal I tried it with a RGsB SIGNAL FROM sKY BOX. gENERATED BY LNKING COMPOSITE SIGNAL TO G signal with a 50ohm resistor. It worked partially. Some issues which need further investigation. you shold ask OWL for comfirmation on whether this is sorted.
    Gordon
  3. Rob100
    Rob100
    Nov 3, 2002
    3,468
    +227
    Gordon, thanks for your reply.
    I have spoken with Owl and it was suggested that the CS-2 was a better bet as this can sync on composite. Apparently there are some issues passing a PAL progressive signal though the CS-1/2 at the moment, so for now I will wait...
    Rob.
