Center speaker?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by SystemBlack, Feb 19, 2003.
  1. SystemBlack
    SystemBlack
    any advice on a good quality centre speaker, not too big but good nevertheless. Thanks in advance
  2. nathan_silly
    nathan_silly
    Something from the matching L/R manu. (Realistic)
    Btw you do need a sub! My L/R's go down to 36hz, but my Subwoofer increases LF sound quality, as well as taking strain from the L/R channels.
  3. SystemBlack
    SystemBlack
    Thanks, I was considering a sub but when I played Lord of the Rings part one, I could feel the floor shake and the bass just ripped my heart out (almost ) even though my main speakers are 50cm from the floor, perhaps the eltax are just a good set of secondary speakers or my floorboards are loose, thanks for the info though, I guess the only way is to borrow one and try it out.
