Center speaker won't work
Discussion in 'Home Cinema Speakers' started by user10293, Jan 21, 2005.
  1. user10293
    user10293
    I have a Logitech X-530 with a Turtle Beach Riviera sound card and my center speaker doesn't work. I tested it in games and used the software that came with my sound card and it still doesn't work. I've tried uninstalling and installing the drivers but that didn't work. However, I tried plugging the center speaker's cable into a different port(don't know the correct term for it) and it worked at that time. Do I have damaged hardware or do I need to adjust my settings?
  2. tom_nieto
    tom_nieto
    May 21, 2003
    418
    Brighton
    The problem will be in your settings. Have you enabled 5.1 sound in the windows sound control panel? Centre speakers are a funny issue on computers, and half the time they seem not to work!
  3. pragmatic
    pragmatic
    Nov 9, 2004
    12,120
    +1,678
    Some times the connector for the centre/sub is the wrong way around, in which case your sub will be geting the highs and mids while your centre is getting the lows.
    You can probaly get a phono swaper, which whould turn the left into the right and that would hopefuly fix it. Try maplins.
