center speaker woe
Discussion in 'Home Cinema Speakers' started by nigelcraft, Sep 21, 2003.
  1. nigelcraft
    nigelcraft
    Mar 18, 2001
    79
    uk
    i have a technics sa-dx940 and when im watching a film in dolby digital the sound from the centre speaker is really quiet,ive tryed turning up the centre speaker volume but that doesnt help and if i turn the main volume button up when there is a loud noise or lots of action it nearly brings the house down,so i have to struggle to hear the dialogue or put up with the neighbours complaining,do i need to buy a better center speaker?
  2. nathan_silly
    nathan_silly
    Fiddle with dynamic range compression and dialogue normalization (if you have these settings)
    Dynamic range compression will elevate quiet bits, but lessen the loud bits. I find it flattens it out too much.
  3. nigelcraft
    nigelcraft
    Mar 18, 2001
    79
    uk
    cheers for that
    ive got dr comp on it,should i set that to max or off,which would give me louder center speaker sound
