center speaker / subwoofer
Discussion in 'Subwoofers' started by figlio, Feb 3, 2003.
  1. figlio
    figlio
    Dec 17, 2002
    179
    Malta
    Hello,
    It is ok to make the center channel on the subwoofer?Or this can couse problems?
    Best Regards,
    Robert
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    I am not sure that I understand the question but if you mean "Can you place the centre speaker on top of the subwoofer" I think that the answer would be no, as the centre speaker should be on asolid base and a good subwoofer will probably produce vibrations.
  3. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    Technicaly a "Good Subwoofer" should should be properly built/ braced so it has has no enclosure vibrations at all.
  4. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Technically I don't see how that is possible.
  5. micb3rd
    micb3rd
    Dec 8, 2001
    1,047
    48
    Bedfordshire
    +67
    This is one of the ways bracing in a subwoofer system.
    http://groups.msn.com/KyleStevensHo...iysubwoofer.msnw?action=ShowPhoto&PhotoID=362
    http://groups.msn.com/KyleStevensHomePage/tempestprojectdiysubwoofer.msnw
    OR like this...
    http://www.adireaudio.com/Files/MetricSealedShivaApplications.pdf
    Here is the main PDF for more info on the Shiva.
    http://www.adireaudio.com/Files/SealedShivaApplications.PDF
    Also many people in America use Sonotube which is a cylinder
    for holding concerete, it is made out of cardboard, is extremely strong, this makes a great subwoofer enclosure, all you do is add 2 inch endcaps and a tuned vent of so required. People in the USA and Canada use it right up to huge subwoofers with 7-8 cubic feet of internal airspace.
    Also there is these ways...
    http://www.jlaudio.com/tutorials/bracing/index.html#types
