center speaker shelf
Discussion in 'Home Cinema Speakers' started by squirrely, Sep 28, 2003.
  1. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    Hello everybody,can anyone tell me where i can buy a center speaker shelf that sits on top of the tv, ive looked everywhere but no luck. thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    erm most people put the centre on top of the TV why do you need a shelf?
  3. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    there is not a flat enough surface on the top of tv so i wanted to do this.
  4. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    Exactly what i need for on top of my Toshiba PW23P, any idea where to get one?
  5. nathan_silly
    nathan_silly
    Jit- LMK how you get along with that centre speaker shelf with the 42PW23P (I've got the same RP)
    Not sure if it'll hold my 11Kg centre though.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    A few companies make item like this for the top of CRT PC monitors worth looking through a Lyreco or viking catlogue at work or the website. I think Fellows do one through Staples as well or if you have a B&O Avant there is a specific bracket available.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Possibly Unicol would do them as well.
  8. Mogli
    Mogli
    Feb 25, 2003
    764
    43
    +124
    Yeah tell me about... I need one to hold my 13kg one! :devil:
    It should help spread the weight around though...better then it being concentrated on just the top portion of the tv.
    klaus where did you get the pic from?
    Anyone else have any ideas where to get one?
  9. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
  10. cskates
    cskates
    Jul 5, 2001
    151
    Belfast, UK
  11. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Nearly 4 x the price !
  12. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    And the Rega is a wall bracket and not a TV top stand.
  13. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Look again, there is a centre mount SENTA ,above the wall shelf.
    Still a lot of money though.
  14. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    Yes, i see it now.
    I'm using a Tannoy Revolution Centre which is 17Kg along with my Toshiba 42PW23P RPTV.
    Would the Farnell one work with this combo?
  15. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Don't know yet mate. I have a huge Paradigm CC350. I can't see a problem though as my tv supports it ok, it just over hangs the screen a bit to balance. With the shelf it should sit nicely.
  16. Tracey
    Tracey
    B-Tech sell a 'set top centre speaker platform' it's only £11.99 including VAT, plus £2 p+p, and it's available in black or silver. Their website is www.b-tech-int.com you can order by calling 01689 848 535 or you can e-mail them your details. I was going to get one myself but may not need one now.
  17. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
  18. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    klaus.
    That one only holds speakers up to 7Kg, i think most of us need something a bit stronger.
  19. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    i didnt particularly want that one i just used the pic to aid description anyway ive ordered one now from farnell,it'll do for me. Thanks mylo.
  20. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    klaus.
    Let us know if the stand is any good as i could do with one.
  21. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    delivered yesterday and its fine for me,its all metal no plastic and it takes my speaker easily, although i think my cs is smaller than most on this thread(quad11c).if your tv can take the weight im pretty sure the shelf will.
  22. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    How far do the legs extend down?
    I'd be using it with a Toshiba 42PW23P RPTV which slopes downward quite sharply at the back.
  23. Mylo
    Mylo
    Mar 13, 2003
    5,541
    +372
    Phew !!!!!!! Glad it works.:)
  24. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    with rubber stops on each end they go down approx 7.5 inches.
  25. Mr Pumpkinhead
    Mr Pumpkinhead
    Jun 4, 2003
    245
    North of the River
    +12
    Which make/model did you get in the end and where from?
  26. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
  27. JIT
    JIT
    Mar 2, 2002
    1,186
    38
    Glasgow
    +8
    Sounds good, i think i'll be ordering one.
  28. Mr Pumpkinhead
    Mr Pumpkinhead
    Jun 4, 2003
    245
    North of the River
    +12
    klaus, What are the dimensions of the top plate?
  29. squirrely
    squirrely
    Jun 8, 2003
    556
    Way out West
    +78
    it's tapered from front to back,width front 14inches,
    width back 5.5inches.depth 11.5 inches.
  30. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    Will this stand work with the Tosh 42WH36 RPTV?
