Center speaker for RX-V673
rdrifter
Please I need some help regarding my speaker upgrade. I am planning to make some changes to the Center and Front without spending too much. I have got RX-V673 along with Canton Movie 85 CX speakers now.
I saw below speakers on eBay
Mordaunt Short MS304 Center (55 Euro)
Mordaunt Short Avant 902i (95 Euro)
Is it worth the upgrade?
PSM1
Those should be a step up from your current speakers. Although they are the same make I do not think they are the same model. Hence I would probably look for the same model across the front 3.
rdrifter
Thanks PSM1
You are right about the CS, its not the correct match.As per some old posts Mordaunt & Short Avant 905i Center seems in the same category as 920i
rdrifter
got one more option
Infinity Alpha 5 - Front + Center + Rear + Sub (€250)
How is this compared to Mordaunt 920i? and is it suitable for the Yamaha Amp?
rdrifter
Well at the end bought the Alpha 5 for €200. I thought it was better than getting the MS speakers as it was hard to find a matching CS.
For the time being I am enjoying it, but am sure that will change very soon ;)
