Center Position
Discussion in 'Home Cinema Speakers' started by jelly, Oct 2, 2003.
  1. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    at the mo i have my front left right speakers around 3 feet either side of my tv with my center on the tv which makes it 2 feet claser than the fronts. would i be better having the center on the wall (same distance from me
  2. sdh500
    sdh500
    Yes, jelly you are right in thinking they should all be about the same distance away from you so you can either choose your own solution above or slightly lower the volume of the centre speaker.
    (BTW, if there is a facility on your amp which allows you to state exactly how far away the speakers are from you then use this and the amp will adjust the volume automatically)!
