Cell processor!
Discussion in 'Nintendo Forums' started by CrispyXUK, Jan 27, 2005.
  1. CrispyXUK
    CrispyXUK
    Feb 5, 2003
    3,742
    71
    Land of the Living, Essex
    +37
  2. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    What's the optimum, max, usual etc temp of chips and hardware. Why is 85c unlikely. No nothing about hardware. :confused:
  3. CMcK
    CMcK
    Mar 18, 2003
    409
    Scotland
    +30
    Why can't Cell run at 85 deg C? It's a Power core with some added on APU's. The G5 processor from IBM, also a Power based chip, is designed to run at 85 deg C. If the G5 can be used in my 5cm thick iMac why not a console with a custom cooling solution? The Cell processor will also be on a more advanced process probably 65nm with SOI which will reduce the size and power consumption. Even with 8 APU's a Cell chip will probably use less transistors than an Athlon 64 or Pentium .
    Let's wait and see what the ISSCC brings next month.
