Celestion S8 output far from specs!
Discussion in 'Subwoofers' started by Gman85, Dec 25, 2004.
  1. Gman85
    Gman85
    I have a set of celestion F series speakers, all which perform to their Frequency responses qouted at +- 2db. The S8 sub is qouted at 35hz as its bottom, however i'm not getting anything low.
    Is this a sub fault or an output from my amp fault via the LFE?
    How can i increase the low end, i've tried re-locating it but it makes little difference.
  2. Nimby
    Nimby
    Jan 27, 2004
    9,204
    The Danish Bacon Factory
    +670
    First obvious question is: How are you measuring your sub?
    Putting a sub right into a corner, as far as possible from any door and window, will usually maximise output.
    Nimby
