Celestion Ditton's
Discussion in 'Home Cinema Speakers' started by Nixon, Jul 31, 2003.
  1. Nixon
    Nixon
    Hi guys (& gals),
    I have recently aqquired a pair of georgeous Celestion Ditton 44's. These are my first set of 'real' speakers yet. I am currently in the middle of buying an amplifier (maranzt 4300/yam 440) and was wonding what these sounded like? Has anybody else had a pair, oh yeah and how should I wire them when I get the amp? they are:
    4-8 ohms
    44 watt normal loading
    My new amplifier is going to be able to send 80/90 watts down each channel will this be a problem?
    Thanks. Jack
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,390
    Somewhere in South Yorkshire
    +5,779
    Nice speakers. Lovely, warm sound without being indistinct, and quite capable or reproducing subsonics down to a few hz.
    IIRC the max power handling of these was quite low (less than the 80/90w you quote) but this isn't an issue. They are VERY efficient (ie produce lots of noise for few watts).
    It is usually safer to have an amp rated higher than the speakers (rather than the other way around) because, overdriven speakers very quickly begin to sound 'nasty' and you are thus prompted to reduce the level, whereas and overdriven amp will sound less 'nasty' but may produce excessive HF levels (clipping) which can wreck your tweeters before you realise you are doing it.
    I have a pair of Ditton 66's (no longer in regular use, unfortunately - space reasons). And ONE of them produces room-filling volume from an old mono portable radio rated at 3 watts RMS. The 44's were similar in this respect.
    Enjoy....
  3. Nixon
    Nixon
    So.... say my amplifier can send 80 watts to each channel and the speakers are only 44 (i think) if i turn the amp up too high could it damage the speakers?
  4. LV426
    LV426
    Jul 14, 2000
    13,390
    +5,779
    Yes. But, as I say, if and when you do this, the speakers will sound so 'nasty' that you WILL turn it down before it's been long enough to do any harm. Unless you are hearing impaired or extremely careless.
    Bear in mind that, at even fairly high listening levels, the full power of the amp will only ever be used for very brief moments and the speakers will cope with this unsustained overloading.
    And, because they are so efficient, you WILL be inclined to keep the amp power down. An under-run amp produces a cleaner signal than an over-run one. There is nothing wrong with using these speakers and this amp, unless, as I say, you behave irresponsibly with it.
  5. Nixon
    Nixon
    thanks and you can be sure that I will be carefull with them. There a prized possesion.
  6. LV426
    LV426
    Jul 14, 2000
    13,390
    +5,779
    Indeed. They don't make them like they used to........
  7. Eros69
    Eros69
    Apr 2, 2008
    2
    Hi Nixon please note your beautiful ditton 44s are actually rated at 10 - 80 watts per speaker ...NOT 44 as you thought ..i collect the dittons ..welcome to the best sound in the world and enjoy them ...
  8. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    I also collect dittons, and I use an arcm pre with 2 arcam fmj P1 mono blocks with some 66's - have also used this with some 44's some 442's some 15's some 551's etc and no problems - the P1's give 170 watts each speaker at 8ohms and 250 at 4 ohms.
    Usually the more power the better the sound, just dont turn the volume up all the way!:smashin:
    You are far more likely to damage the 44's with an underpower amp turned up as this will give distortion and blow the tweeters (HF2000) - the tweeters sell for £50 each on ebay.
    btw if you like the 44's you would be amazed by the 66's, and if you get an chance to get some 551's or UL10's go for it - they have a dome mid as well and sound cracking!:smashin:
  9. Nixon
    Nixon
    Hi Dave,
    Talk about bringing a post from the past up lol, 5 years ago when I first posted this mate! Only a wee lad of 15 back then and I'm touching 21 now :eek:
    I've still got my beautiful set of 44's running, on the same amp (Marz SR4300) and they're continuing to serve me well. They've been put through their paces as they've seen me through my early teens and now I'm at Uni.
    They've made a few friends along the line such as my rear JBL Control 1's and my Tannoy MXc center and they seem to compliment each other perfectly.
    I'll keep my eyes open for the others you mention, are they the same sort of size as my 44's?
    Regards,
    Jack
  10. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    That will teach me to check the post dates!
    Yes the other speakers I mentioned are about the same size but have much better mids.
    Good luck at uni
    Dave
  11. Eros69
    Eros69
    Apr 2, 2008
    2
    Hi yes the 66s are next on my list i have a pair of 44s still have the original boxes too they are in mint condition also a pair of beaten up 33s and pair of 22s ..next on my list is 2 pairs of 66s
    Im looking forward to getting these i will be travelling to france and germany to get these which shoud be fun
    Does anybody have advice for me ..i want to make new cabinets for the 33s but will not use mdf or chipboard .. i heard somewhere that its better to renew the resistors and electronics on the crossovers is thsi true ? if so is it easy
    also could do with advice on a top amplifier to use with my 44s oops i made mistake by the way ..i stil have the users data sheet they are actually 10-100 watts not 10-80 thats the 22s and 33s ..apologies for that folks
  12. steve4
    steve4
    hi,
    have just bought some ditton 25's as they were ones my dad had when i was a young'un - are they generally deemed to be the black sheep of the ditton range - ie not as good!! i knocked back some 44's recently thinking i wanted the 25's......
    i am in the market for perhaps the 44's and or the 66's at the moment but perhaps am naive to think money can just buy them....any ideas how i can get some....are you considering letting some of yours go??
    cheers
    steve
  13. steve4
    steve4
    you are not interested in freeing up some storage space and selling thosee 66's are you?
    steve
  14. Nixon
    Nixon
    Haha join the queue steve4, a reasonably priced pair of 66's are a nightmare to find. ;)
  15. albriscoe
    albriscoe
    May 29, 2007
    5,360
    ideal home cinema dem room
    +522
    Blooming Hummers
    When I worked in HiFi back in the 70`s we sold all the Celestion range and the 66`s were a joy to listen to as were the 44`s.
    Being quite efficient and driven with something like a Sugden or similar the shop was filled with probably one of the best audio listening experiences of the time and was sold well.
    Some of the Ahem, older members on here might remember the Quad Electrostats which were a flat radiator looking loud speaker with great potential to be probably the most cleanest sound reproducing speaker of its day, infact some of you will probably still have a pair.
    Well on the strength of this accolade we sold more Dittons after demoing the 2 pairs together because they were that good.
    So a good pair found today for a reasonable price should be an achievement to saviour and the new owner should hopefully come to love them as others do.
    Allan :smashin:
  16. Sleepy
    Sleepy
    Sep 29, 2007
    844
    28
    +43
    i have a pair of ditton 15 xr
    are they worth anything?
  17. Nixon
    Nixon
    Theres a dozen of them going on ebay at the moment and they don't seem to be fetching a decent price. I don't know if they are any good or not, how do you find them?
    Jack.
  18. chr15e
    chr15e
    Oct 20, 2008
    2
    I have a pair of 66s.
    Had them about 5 years now. I bought them out the local admag by chance. Didn't even know they existed.
    I had a pair of 44s at the time which I was very happy with but had to go and see what the 66s were like just out of curiosity.
    The guy turned out to be a carpenter and had remade the cabinets and upgraded the internals.
    I quickly gave him £250 and haven't looked back since.
    I run them on an old Pioneer A-757 amp.
    Here's a pic of one.
    [​IMG]
  19. Nixon
    Nixon
    wow, they look stunning mate. :eek:
    Well done for finding a bargain! :clap:
  20. shakeelraza
    shakeelraza
    Hi everyone- I have just acquired a pair of Celestion Ditton 44's that my Dad bought it the 70's and they sound unbelievable!
    The amp i am using is rather fragile now and I am looking to buy a new one but I am not sure about what will be best compatible?
    For example would this be okay?
    TA-FE370 (TAFE370) : Home Theatre and hi fi : Sony : United Kingdom
    I really don't want too damage them! can anyone suggest some ideal amps?
    Shakeel.
  21. Fred the Oyster
    Fred the Oyster
    Mar 23, 2008
    128
    Manchester
    +7
    Maybe a Quad 33/303 or an Armstrong 621? :devil:
  22. shakeelraza
    shakeelraza
    Cheers- I've just searched for this old amp 'Sansui 661' and it gets great reviews- I must admit it does sound amazing but I thought it was the speakers themselves.
    Is it normal to have a bit of noise when using the volume/ balance faders or is this a bad connection or something- also there is a fair bit of hiss but that may be as it's analogue but it sounds great all the same.
  23. steve4
    steve4
    hi - steve4 here....
    managed to get some 66's (though have had to get the mid range speaker repaired...found an old fella who repairs them....
    and got some 44's also ... am wondering what sort of amp to power them....
    got a really nice sugden which is powering a few celestion 15's but it is not really able to drive the 66's
    ...any suggestions?
  24. macguffin
    macguffin
    Mar 11, 2005
    498
    +8
    Thread resurrection.....ha over a year nearly. I have just bought a pair of celestion ditton 44's. I'm looking into buying a vintage amp, sansui or sugden. i'm looking at a Sugden A21a or Sugden A28 amplifier for that nice warm valve sound and was wondering would these amps be ok to drive the celestions.
    The a21a is rated at 25 wpc and i think the a28 is not much more at 35-40 watts. These amps are class A amps so run hot and therefore really work best with very efficent speakers but i dont know how efficent the celestions are. The celestions are rated at 10-80 watts but does anybody know the decibel rating?
    any help appreciated
    thx
    macguffin
  25. unrealdave
    unrealdave
    Mar 7, 2005
    252
    Romford
    +11
    The 44's are great speakers - you should try the 66's :smashin:
    This is from the original literature at the time
    Ditton 44
    Recommended Amplifier 10-100 watts rms
    Freq response 25hz - 40 khz
    Sensitivity Pink Noise Input to give 90 dB SPL at 1M 4.0 watts rms
  26. macguffin
    macguffin
    Mar 11, 2005
    498
    +8
    Thanks for the info unrealdave, i wish i could afford a pair of celestion ditton 66's....they tend to go for about £500, once i seen a pair go for over £1000...unbeliable:eek: Maybe in the future but the little 44's will do me for now. It appears that the 44's 90 decibel sensitivity should be able to handle the sugden amps as long as i dont go to mad with the volume, considering replacment tweeters are nigh on £50 each i will be careful lol
    thx
    macguffin
  27. dandini
    dandini
    Jun 26, 2007
    184
    +9
    Hi Steve,
    What old guy did you find as I need on of my midranges fixed?
    Thanks,
    Dan
  28. suurirakkaus
    suurirakkaus
    Oct 30, 2009
    3
    hi,
    i've bought a pair of celestion ditton 551s and i am thinking of upgrading my cambridge audio 340 amp to a 640a 2, but i am not at all sure that it would be the right choice. it would be nice however to match the amp with the rest of my setup (cambridge audio). does anyone have any opinions about 640a 2 running celestion dittons 551s? also are there any suitable stands still manufactured for the speakers?
    thanks.
  29. mikeeb
    mikeeb
    Feb 11, 2009
    30
    Epsom
    Does anyone have a copy of the orginal specifications for Ditton 44's?
    Just picked up pair after lusting after them since beng a lad when my best mates Dad had a pair. They sound just as great as I remeimber :thumbsup:
  30. Martian Phil
    Martian Phil
    Dec 4, 2003
    247
    Sarf London
    +16
    Pair of 66's just gone for just over £2000 on the bay of E Stunning Celestion Ditton 66 MK2 Monitor Speakers on eBay (end time 13-Dec-09 21:31:13 GMT)
    Wonder how much they were new in the seventies?
