Celestion C ?
Discussion in 'Home Cinema Speakers' started by Malone, Mar 15, 2001.
  1. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Anybody got a set of Celestion C Series Speakers?
    The HCC review says thumbs up, but there's nothing better than personal experience.
    Malone........
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I have the Celestion C's, top speakers, I wouldn't replace them for anything. You do need a meaty amp to make the most of them, they are a good match for the Denon AVC-A1SE.
  3. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    Cheers, im soon to be getting the DSP AX1 would the a 2nd centre be sufficient for an "ex" speaker.
    Malone........
  4. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I have a couple of pioneer near flat speakers as back rears which work well. A rear C4 centre should work very well, how are you thinging of mounting it? I would have thought that high up on a shelf and pointing down towards the listening position would work best.
  5. Malone
    Malone
    Mar 12, 2001
    1,859
    Ilkeston,Derby
    +70
    I was going to have C2's for the front C2's for the rears and possibly, as you say, put a shelf in for the rear centre. Hopefully the C2's for rears should be good.
