ceiling to floor mount
Discussion in 'Projectors, Screens & Video Processors' started by codeone, May 9, 2003.
  1. codeone
    codeone
    May 9, 2003
    48
    Dorchester
    I want to mount my projector a vikron crt take it off the ceiling and put it in a coffee table what do i have to adjust in side the projector to turn the picture the other way up can any one help
    cheers geoff
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    It should explain this in the manual.
    Most vidicrons were Electrohome clones (modified slightly)
    What model is your projector?
  3. codeone
    codeone
    May 9, 2003
    48
    Dorchester
    The model is a vidikron tgs 301 i bought it second hand but it had no manual with it .I set it up on the ceiling about 2 years a go but i doing the room up and i have a big coffee table and it will be out of the way.
  4. Anders_UK
    Anders_UK
    Should be on the internal menu's or something. Just flick from ceiling mode to table mode.
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I doubt it will be a software change.
    You need to reverse the horizontal and vertical scan coils doing this in mid flow would be catastrophic to a CRT tube.
    Beamer have the Italian verion of the installation manual, looking at it, it shows the correct connections for all the scan and convergence plugs. but I would want it properly translated before I started pulling wires.
    "Darling how would like me to treat you to a proper Italian meal instead of me fiddling with the projector all the time?":cool:
  6. codeone
    codeone
    May 9, 2003
    48
    Dorchester
    ok mate thanks have all ready download the file about a month a go i have to try and get it translated and have a read thank you
  7. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,743
    Cheshire
    +107
    High end Videkrons were Electrohomes, but the TGS301 was one of the models sold into the pubs and bars market so its origins may be different. I believe they were manufactured in Italy.
    Satvision, in Stockport, were the UK distributor and dealer for this range. Tel 0161 608 1360 for a manual.
    Regards
  8. codeone
    codeone
    May 9, 2003
    48
    Dorchester
    hi can any one help i phone satvision in stockport to see if they had a manual for this model vidikron tgs 301 but no they have none is there anyone got a manual for this projector in english that i could bye off them or photocopy i have download it off of beamers but it in Italian. thanks codeone :rolleyes:
