Escribblings
Hi.
I'm helping a friend re do the audio for his salon.
Currently he's using an old hifi unit and substandard wire to connect 2 medium bookshelf speakers.
The salon is huge.
He does have budget restrictions, and so far I'm looking at a system that will cost around £175.
I just wanted your input as to whether I have correctly matched the parts, and on the best wiring configuration.
As I said this is for background music, so it won't be pumping out the decibels.
The Salon is long and narrow, so I've gone for 4 ceiling speakers to be evenly placed down the centre of the shop. The bonus to this is than none will be directly above a client's head.
The speakers are Adastra C6S 6.5" Single Stereo Ceiling Speakers
Woofer 165mmØ (6.5"")
Tweeter 2 x 13mmØ (0.5"")
Frequency response 70Hz - 20kHz
Power max. 50W + 50W
Power rms 25W + 25W
Impedance 2 x 8 ohms
Dispersion angle 160°
Sensitivity @ 1W/1m 82dB (±2dB)
The amplifier I've chosen is the Fosi Audio TB10A
Terminating Impedance: 2 Ohm - 8 Ohm
MAX Power Output: 100W x 2
THD ≤ 0.04%
Frequency Range: 20Hz - 20kHz (±1 dB)
SNR ≥ 98dB
Input Sensitivity ≤ 280mV
I was concerned about the terminology "Max power output", as it later states it as RMS in the Amazon advert, but doing some research, it appears the terminology comes direct from Texas Instruments.
The TPA3116D2 is rated to 50 W RMS stereo or 100 W RMS mono, according to this: https://e2e.ti.com/support/audio-group/audio/f/audio-forum/688690/tpa3116d2-tpa3116-power-ratings
The TB10A uses 2 chips, so 100W per channel is feasible.
I plan on using 1.5mm² cable, this is slightly larger than 16 AWG (1.3mm²), but smaller than 14 AWG (2.1mm²).
So that just leaves the connections.
The amp only has 2 channels, rated 2-8R/100W
The speakers are effectively 2 speakers, so my 4 units give 8× 8R/25W speakers.
As I see it, I have 2 possible configurations.
Running 1 chain of 4 parallel speakers per channel, this will drop the impedance to 2R (8÷4=2), and the requirement of the amp will only be 25W.
Option 2 is to run 2 parallel chains of 2 speakers in series per channel. This keeps the impedance at 8R ((8+8)÷2), and increases the requirement of the amp to 50W.
The latter, I think it's the preferable option for balance, but it's slightly more complicated to wire in.
Does this sound like a reasonable setup.
I know it's not home cinema quality, but that's neither required, or within budget.
The salon is huge.
6.5" Ceiling Speaker with Dual Tweeters : Amazon.co.uk: Electronics & Photo
Buy 6.5" Ceiling Speaker with Dual Tweeters. Free delivery and returns on eligible orders.
www.amazon.co.uk
Power rms 25W + 25W
THD ≤ 0.04%
SNR ≥ 98dB
