Ceiling spkr placement advice pls.
Discussion in 'Home Cinema Speakers' started by Taz, Mar 25, 2003.
  1. Taz
    Taz
    where is the best place (dimensions please) to mount a pair of in ceiling spkrs for channels 6.1 & 7.1 going to be? looking from the ceiling down my current layout is as follows...
    ----------------------------------------------- (back wall)
    RR........coffe table.....sofa...............RL
    Do I have to put them eqally spaced betweeen the rears? if so, how far between the in ceiling's? the rears are 3m apart.
    cheers & sorry for the crap explination!:D
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The only obvious thing is that they should go directly between the surrounds and opposite the centre channel.
    I'm not 100% sure how far apart they need to go. It depends on which spec you read. I think certainly no more than 1m apart though, possibly down to 0.5m.
  3. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,554
    7
    167
    Birmingham, UK
    +10,382
    As I understand it they each go at 1/3 along the the rear wall from the site. My setup has 2 EX rears from the ceiling against the rear wall.
  4. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    It looks like they are going in that way by default anyway now.
    Joists are always the first to make a decision!:D
