rhino2k
are they any good for rear effects?
was thinking about putting them in my room for tidyness (in a bedroom so easy to install wires in the loft).
also not sure if i would need or can get ones that allow you to angle the cone towards the area wanted?
any advise or comments welcome, as i've not heard them in action.
main reason is for neatness, may also consider in wall options or very slimline wall mounts
budget is negotiable, just depends really, if i like something money does'nt usually become a problem
