"ceiling" speakers for sides ??
Discussion in 'Home Cinema Speakers' started by tiberious, Sep 24, 2001.
  1. tiberious
    tiberious
    My HC is a loft conversion - the side walls are vertical for 3ft, then pitch at a 45 degree angle with a flat "roof" .
    My question is this - I currently have a 5.1 speaker system (Quadral Ascent line)fed by a pioneer 908 receiver, But I fancy upgrading to a 6.1 system (via the new Denon 3802 receiver).
    the rears are currently on very deep shelves about 4 ft behind the seating position (bipolars) - should I get a new pair of bipolars and mount them on the 45degree angled walls either side of the listening position , and use my existing rears for the EX/ES channel ??
    Is it more important to match the sides and fronts,or rears and fronts ? (Quadral dont make a "flat backed" speaker, so couldn`t match the wall speakers to the rears).
    Any thoughts appreciated,as always.
  2. Stuart Wright
    Stuart Wright
    AVForums Founder Staff Member
    Jan 24, 2000
    14,655
    7
    167
    Birmingham, UK
    +10,542
    Can't comment on most questions you ask, but Ruark are releasing the Dialogue II in the next 2 or 3 weeks which come with a mounting bracket which can be used with ceilings.<br />I'm having 7 for an EX system completely suspended from the roof.
  3. Jim Robson
    Jim Robson
    Jul 14, 2000
    245
    Originally from the wonderful Granite City, Aberde
    Those people from Ruark (and REL) are exceedingly kind to you, Spectre!
    Regards
    Jim <img src="biggrin.gif" border="0">
