Ceiling speakers for Atmos
laboy69
Hi All,
Could someone please advise what celiing speakers should I get? I have 5.1 system- 2x Monitor Audio Bronze 5, 2x Monitor Audio Bronze FX and 1 x Monitor Audio Bronze Centre, AVR - Sony STRDN1080. The size of the room is approximatelly, 3.5m x 4m. I want to add 2 ceiling speakers to make it 5.1.2. The drywall is not set yet, but I try to fit into 12cm size of the speaker in terms of depth. I was looking into Monitor Audio C180, CS180, C180T2 or C280. I would prefer the same brand but other alternatives may work as well. The budget is around 150-200 pounds per speaker.
Thank you for any ideas. :)
Frenky
pyrotenax
Established Member
I have 4 of the Monitor Audio C165 speakers in ceiling of my lounge , and they are superb.
I also installed a Firetopper Pro Acoustic Speaker Firehood for each C165.
dion 6
Hi i have the same Sony STRN1080 reciever and a monitor mass 5.1 surround system i was looking for some small discreet speakers to keep my wife happy. A lot of people are using cambridge audio minx c64 ceiling speakers only 75mm cut out £99 each from richer sounds.
David83S3
I have almost the exact same setup and room size as you Frenky!! How did you get on buying the ceiling speakers ....? What did you go for....? I am about to put in 2 x ceiling and have the same question .... which ones?!?!?!?
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
