NullMind
Established Member
I am sorry, I know this is a questions asked here 100x now, but with every layer being slightly different .. becomes hard to be sure one is on the right track, I tried to do allot of research before settling on this layout, I just ask for some sanity check, see if I got it right taking in consideration the layout I have to work with !
Just double checking this look right
I had to put the center of the back Atmos ceiling at 33cm from the back cabinet, the cabinet goes to the ceiling and houses the rear surrounds, I then placed the center/forward (?) ceiling atmos at 194cm from the back cabinet (center of speaker) .. basically the center of the back atmos and the forward atmos are 1.6m apart
This only allows me a 104º for the back, not the recommended 125º, on the fronts, I do get a nice 46º (from the optimal viewing/listening position in the couch)
I cant push the back Atmos any further back because there is a metal support for the drywalls that prevents me from doing so
Now, distance from the wall, I place them at 0.29cm (center of speaker) from the wall, as to be in line with the front speakers
Now my questions
1 - I cant get a 125-135º for the back Atmos, is this setup worse than just going 5.1.2 ? or will I still benefit from the 5.1.4 despite not ideal placement on the back ? (I already bought the speakers, but can always return 2)
2 - Does the forward atmos at 1.94 from the back cabinet look alright ? my rough calculation gives me a 46º angle to the head of the perfect listening position, the top of the head being at around 115cm from the floor, or should it be further forward towards the screen ?
3 - Is the distance to the side walls or the Atmos fine ? should I keep them in line with the front speakers or push them further towards the inside of the room ?
And of course, if you guys think I am missing something or doing anything wrong .. I appreciate
PS - Before somebody wonders, "where is the SUB ?", it is on a partition in the cabinet, behind the couch ..
Thanks for any help !
Carlos
Now my questions
Carlos
