Ceiling speaker mount
Greggerly
Hi guys
Looking for universal ceiling brackets to mount my speakers. Yes, I know they should be ear level but my office is a tiny room and the only reasonable way to mount them is from the ceiling angled down. I've found a few brackets but they usually require drilling into speakers which I'm not fond of.
Do you know of any cradle tyle mounts that I can use?
Speakers to mount are not the largest ones - Q Acoustic Concept 20. Circa 6kg each.
thanks for any pointers
ShanePJ
AVForums Sponsor
I'm guessing you are looking at using them as high (mounted on the walls high up) and not actually trying to mount them on the ceiling? Vogels offer a universal wall mount however if you are looking to mount a pair of speakers on the ceiling, you might be better better off looking at something like Kef's T101 or T301 speakers as they can be fit flush and the cables are held in place via a small allen key grub screws
