Ceiling- or top-of-wall mounted height speakers
imightbewrong
It's probably a tale as old as time but I'm speccing up a dedicated cinema room in the garden - planning on a 7.2.4 setup. What are the thoughts on mounting angled height speakers on the walls vs in-ceiling speakers? I am focussing on sound-proofing so not wild in cutting four large holes in my ceiling. Also I have some B&W in-ceiling speakers in the kitchen - they sound ok... but a bit lacking oomph - I guess as they are not boxed.
Would four wall/ceiling join mounted height speakers like the SVS Prime for example
give satisfactory Atmos height effects? I guess they could also be surface mounted on the ceiling itself.
gibbsy
In ceiling will be better, especially if that ceiling is fairly high, more dispersion. Height of the ceiling is also going to effect how the front height mounted ones will work, again higher the better. Upfiring will work if the ceiling is over 7.5-8 feet and is made of a reflective material. Four speakers will give a very wide dispersion in that configuration.
I'll not comment on the sound proofing, or not, of inceiling speakers as I have no idea but they would be the best option if you can accommodate them.
imightbewrong
Thanks - to be clear I'm not thinking about up-firing but rather down-firing - like this
AmericanAudio
AVForums Sponsor
Exactly what the 'Elevations' were designed for.
X4100
That is the best way to do it, it wil envelope you in ATMOS! I ran my 5.1.4 that way prior to going to front and rear heights. Love your idea my friend
X4100
@imightbewrong what setup did you use, and what is your thoughts about it?:D I just love the immersive experience I have with my 5.1.4 front and rear heights :clap:
imightbewrong
Haven't got there yet - still not sure if I should be putting the atmos speakers on the ceiling, in the ceiling or at the top of the walls 🤷‍♂️
kenshingintoki
Marshall Mike
@imight what setup did you use, and what is your thoughts about it?:D I just love the immersive experience I have with my 5.1.4 front and rear heights :clap:
Hi, are you saying that you firstly had down firing speakers as per the picture, but now have in ceiling speakers?
X4100
Not able to have inceiling setup as I'm renting. Mine are close to the ceiling wall juncture pointing to the MLP ( 1 seat: ME) Lol :clap:. I'm currently running front and rear heights.
X4100
WOW WHAT A BLAST!!! I just had. Before making any adjustments I remembered some of the things discussed in this thread. So I put on Godzilla King of the Monsters. First let me explain something, I purchased the x4100 when it first was introduced. I worked during the day, and by the time I got home so did my landlady. When I watched movies I never went above-30, on weekends when she was out of town and when my wife was at work. I hit the restore button to go back to the setup audyssey made when I first used the x4100. This morning I watched, mainly listened at-20. Man I heard the bubble thing others talked about, I put MV on-10. To make things crystal clear to everybody the audio I heard was incredibly indescribable!!! Jets and those other aircraft were flying in all directions directions in my room, and on the ceiling. When Godzilla started to stomp around the entire system was hitting harder than I ever imagined, and this was without making a single adjustment to my setup. The only thing I did was I was listening at close to reference level in my little room! I'm ssssooo excited about my system this nitpicky tweaker has declared game over. Thanks to all of you for sharing your thoughts, I will eat lunch and call it a day!! :clap: :D:p:clap:
X4100
Just wanted to add to my post yesterday. I'm running a 5.1.4 height configuration. Sometimes I read that a poster says they are disappointed in Dolby Atmos, I now wonder whether they have the MV at the right setting. To be honest the closer I was listening near reference level the sound just smoothed out, and every speaker was working in unison with the setup! Some sounds that I thought would be overhead weren't, but the next second everything was where it was supposed to be. Now I understand why I read on this forum that some listen at-10 master volume, next movie is Godzilla vs Kong maybe at 0 reference level :clap: :clap: :thumbsdow:rolleyes:
kenshingintoki
Listening at reference is amazing.
sad I have my right ear playing up at the moment so haven’t been able to play with my toys in a while
what power amplification u using at reference (
X4100
LCR is powered by x4100 denon, l/r surround is powered by my avr 2802 denon, and the front and rear heights are powered by their own 100 watt 2 channel stereo amp. I'm in a 12x12x8 room.
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
