Quantcast
Ceiling mounts
ReTrO
Simple question: so the Domino series share common mounting holes/fixings with the HT series?
For example: would a Domino 20 fit onto an HT300 mount?
I'm guessing and hoping they do as they appear to be indentical visually in the mount side, but as there don't appear to be any images of the mounting point I can't tell.
chips
Yes, the metal ceiling/wall mounting kit is the same for Domino and HT series. I bought one on the classifieds here, the vendor used it for a Domino and I'm using it for an HT300.
ReTrO
Cheers Chips.
Very good news. :)
RTFM
Bear in mind the throw ratio is longer on the Domino 20 than the 300 series if you were keeping the mount in the same place and just swapping projectors.
One of the great attributes of the Sim2 projectors is that they can sit the right way up on a fairly high shelf on the back wall.
ReTrO
I am not to worry Jeff.
I was asking as the mount is going on an Audipack lift and was listed as being for an HT300.
