Ceiling mounts Sony HS2 v HS10
Discussion in 'Projectors, Screens & Video Processors' started by fozziebear39, Feb 5, 2003.
  1. fozziebear39
    fozziebear39
    Jan 3, 2003
    1,009
    Newton-le-Willows
    +49
    I have a Sony HS2 at moment but it's going back and being swapped for an HS10 when they have it in stock.
    I have made a ceiling mount for HS2, just wondering has anyone seen both and are the bolt holes on the underside in the same postion for both projectors? I know the HS10 is a larger pj.
    The HS2 has four bolt fixings in a square at 96mm centres.
  2. museumsteve
    museumsteve
    Jan 28, 2001
    7,925
    4
    Nth Hampshire
    +1,075
    the HS-10 has 3 bolt points in a triangle mate..
  3. Ghidorah
    Ghidorah
    Oct 16, 2002
    143
    19
    Bristol
    Hi Fozzie,
    Ghidorah here.
    Got the HS10 at last boy what a difference.:clap:
    No sign of screen door, a muchbetter PJ for the money.
    Yes it is a bit louder but you soon forget about it when you look at the picture.
    Hope you like it as much as I do.
    Let us know when you get yours
    Cheers mate Ghidorah
