Ceiling Mounts for Projector advice?
Discussion in 'Projectors, Screens & Video Processors' started by HDPete, Jan 21, 2004.
  1. HDPete
    HDPete
    Jan 15, 2004
    281
    Ringwood, Hampshire / Dorset Border
    +14
    I have an NEC VT440 LCD projector and I need to ceiling mount it. There is an NEC V40CM part (ceiling mount) but is £180.
    Is there a generic mount anyone can recommend (with links to the product if poss)?
    I'm looking at: http://av-sales.com/projectors/html/vogels_universal_supports.html which seems ok. Anyone experienced this product?
    Pete.
  2. Bill
    Bill
    Oct 31, 2002
    509
    3
    Dungannon
    +32
  3. HDPete
    HDPete
    Jan 15, 2004
    281
    +14
    Thanks,
    I need a mount that gets the projector as close to the ceiling as possible, and these seem a bit long. I've dropped them an email to see if they can custom make.
    Pete.
  4. VirusKiller
    VirusKiller
    Mar 15, 2003
    1,804
    Hogsty End
    +70
    Off thread I know...
    dslpete - aren't your Kef Crestas somewhat outclassed by the rest of your kit?!!!!!
  5. Daftboy
    Daftboy
    Jan 8, 2004
    505
    +12
    Have you tried Unicol?
  6. HDPete
    HDPete
    Jan 15, 2004
    281
    +14
    Virus Killer - they are somewhat, but even the guys in the dealership were amazed at how well a cheapo set of speakers could perform with the Meridian.
    I'm actually awaiting delivery, and over time, I'll upgrade the speakers to DSP Actives. But for now, the cash has well and truly run out!
    Pete
  7. Jack the lad
    Jack the lad
    Jan 12, 2003
    2,033
    New Zealand was Nottingham
    +86
    All of LMP's mounts are custom made.
    And they are the best looking and well made bit of kit you are likely to see. Bar none. :)
    Jack
  8. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    I second that - I bored many friends by saying 'Look at the machining on this mount' before I actually got the thing installed :D
  9. nunew33
    nunew33
    Jun 5, 2002
    1,735
    41
    Lytham St Annes, where people are put out to grass
    If you dont thread your cables through the mount then the mount shaft can be as short as you want. I got the 10cm one which will be the shortest if you do intend threading cables through it.
  10. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,416
    In a secret location with Jennifer Lawrence
    +7,245
    Another recommendation for LMP-pc.co.uk
    Excellent service, friendly, and amazing quality product for the price. They are all custom made so you can specify whatever mount length you want.
    Greg
  11. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,309
    Surrey. UK.
    +2,019
