Ceiling mounting Z2 - help.
Discussion in 'Projectors, Screens & Video Processors' started by Kane D Williams, Dec 18, 2003.
  1. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Hi there
    Can anyone tell me what size (thickness) bolts/rod I need to fix the Z2 upside down to a DIY mount? Also, how much clearance is needed to allow the removal of the air filter?
    I bought a pair of speaker wall brackets from Maplin, which seem perfect for a cheap DIY mount. They can be moved in all directions to allow 'easy', precise set-up and can take up to 10KG's. I intend to fix the Z2 to a piece of 8mm MDF or Perspex (10"x14") with 3" threaded rods to allow further adjustment via wing nuts.
    The brackets cost me £15 and I would be up for selling the spare one (see free-ads)
  2. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Does nobody know what size (thickness bolts) fit into the feet holes for mounting the Z2? Oh well, I'll just have to wait till I get it! Getting excited!!!
  3. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +215
    I'm pretty sure I read that they're M4 sized.
    Your best bet is probably to pop down to your local DIY store and buy a few to test for size.
    You could always take them back for a refund once you've found out which ones you need.
  4. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Cheers Bursar
    I believe I had heard they were M6 and was hoping someone would confirm this, but instead you say they are M4 - HaHa!
    I will simply wait and take one of the legs/feet to the hardware place.
  5. markbro
    markbro
    Sep 25, 2003
    56
    Co. Limerick, Ireland
    The three threaded holes on the Z2 take an M6 screw, that is what is supplied with the LMP mount.
  6. Bursar
    Bursar
    Jun 29, 2003
    2,405
    63
    Cambridge
    +215
    Ah well, just goes to show - I was completely wrong :)
