Ceiling mounting Hitachi tx200
Discussion in 'Projectors, Screens & Video Processors' started by duffy78, Mar 15, 2006.
  1. duffy78
    duffy78
    Jul 1, 2005
    1,504
    48
    +89
    ive just ordered a hitachi tx200 and was wanting to mount it on my ceiling at home, i was wondering if anyone could suggest a suitable bracket and somewhere i could purchase a suitable bracket.
    my thanks in advance
  2. redrider
    redrider
    Does anyone had a suggestion for this? I have just upgraded from a 100e to a TX200. I have been using a Vogel's celing mount but unfortuately the TX200 requires larger size (6mm) mounting bolts! Now I have to upgrade my ceiling mount as well!
  3. bladerunner8801
    bladerunner8801
    Jun 4, 2003
    409
    UK
    +39
    I have a universal Ceiling Mount that i never used has adjustable height, tilt angle, if interested i will send you more details. its minimum length is 24" extends to about 3ft
  4. Cocksure
    Cocksure
    Oct 27, 2005
    4,441
    Manchester
    +1,547
    Why cant you just re-drill the holes in the bracket so as it can take the large size screws?
  5. kdog
    kdog
    Mar 6, 2006
    360
    Ayrshire
    +61
    Thats exactly what I did Lizard. I ordered my vogels mount and then noticed the srews and hole dia were too small. A 6mm drill and a trip to the local B&Q sorted it:thumbsup:
    Duffy78, go for the Vogels mount (about £130) a lot nicer looking than the universal (industrial) one shown.
  6. redrider
    redrider
    Lizard, kdog....that is exactly what I ended up doing. I agree that the alternative mount pictured does not look as atractive as the Vodels mount.
