Ceiling mounting a Z1
Discussion in 'Projectors, Screens & Video Processors' started by Underscore, Dec 17, 2002.
  1. Underscore
    Underscore
    Ok,
    I should be installing my Z1 just after Xmas - no time to beforehand - but apparently it needs to be 1.35-1.6 times the screen-width away - which, given my screen's measely 5' width, means I won't be able to screw the Unicol mount directly into a joist. The house construction makes installing a noggin above very difficult, so has anyone used heavy duty plasterboard fixings to fix their projector mount to the ceiling? Alternatively, will I need to make a wooden structure to bridge the two joists, if I don't want to end up with a floor-mounted projector in the middle of the night?
    TIA,
    _
  2. Gary Lightfoot
    Gary Lightfoot
    Apr 6, 2001
    12,302
    Surrey. UK.
    +2,016
    Most joists are 14ins apart - can't you fix to one and zoom in/out to fit the screen?
    Plasterboard fixings may be OK if the ceiling is plasterboard and not old lathe and plaster (which tends to crumble), but to be 100% secure, you could make up an mdf sheet (router the edges and paint to give a nice finish) and fix between the two joists as you suggested.
    If done well, it'll look fine.
    Gary.
  3. Sly
    Sly
    Apr 28, 2002
    1,458
    west mids,England.
    +48
    i was gonna ceiling mount mount mine but after looking at ceiling(house built in 1902!)i went for a wall mount instead.
    brought a wall mount designed for 14-16 inch tv's from focus diy priced at £14.99.
    at 11 feet i get a screen 6 feet wide which is big enough for my small (12 by 12) room.
    dont know if this is any good for your room , but they are worth a look at , and are available in white or grey.
