Ceiling mounting a Tosh ET1
Discussion in 'Projectors, Screens & Video Processors' started by wookie, Apr 7, 2005.
  1. wookie
    wookie
    Hi Guys,
    I should be receiving my ET1 in the next few days.
    How would this PJ be mounted on the ceiling?
    Can the swivel mount be utilised?
    Any info appreciated.
  2. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Hi Wookie,
    If your ET1 has the standard 3 threaded mounting holes you could get the same mount I got from CPC for my Sanyo Z1. Have a look here and here . You will need to order both the mount and carousel.
    The mount can swivel 360 and I think CPC do a longer version if you have a high ceiling.
    Hope this helps!
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,134
    +564
    I asked this question a few days ago, here's the reply...
    "Yes - the tilt and swivel base comes off and it has fairly standard-ish mounting holes. I guess it would work with a cheap universal ceiling mount off ebay. The setup screen also has electronic inversion."
    ...PJ
