Ceiling Mounted Projector Connections
Discussion in 'Projectors, Screens & Video Processors' started by Josh_P, Dec 24, 2003.
  1. Josh_P
    Josh_P
    Hi all
    I've posted this in the Projector section, but seeing as most of you have ceiling mounted screen you may be able to help me.
    I am about to mount my Sony VW-11HT to the ceiling, however, as it's not a dedicated room (living room), I will be taking it down when not in use.
    I was wondering how you guys wire up your projectors, do you have a socket outlet mounted in the ceiling for power and a socket like those sold by 'letsautomate' Here for video connections?
    I really don't want wires hanging through the ceiling and would like the neatest possible solution.
    Would appreciated your thoughts and what solutions you guys came up with.
    Best regards and Merry Christmas
    Josh
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    Iw ould leave it up all the time mate!!! dont use sockets. You can just run a VGA lead back to an Iscan in equipment rack and have a recessed hole for the vga lead to tuck into but why take the PJ down?
  3. Godfather
    Godfather
    Feb 12, 2001
    2,223
    63
    Edinburgh
    +224
    I've a Sony VW12 and I can't imagine the hassle of having to take it down between viewings! You'll have to unplug all the cables and unscrew the thing from the mount, and the pj is fairly heavy so you'll probably need someone to give you a hand each time you take it down and put it back up. You'll also have to realign the pj everytime!
  4. Josh_P
    Josh_P
    Cheers Gents
    Unfortunately I cannot leave the projector up full time, one reason being that there are smokers in the room and don't really want it full of nicotine!!
    Godfather
    The mount I have is a Chief RPA which allows for quick release and mounting without having to realign it each time.
    Surely there must be other people on here that don't have their projectors mounted full time!!
    I don't mind having to take it down, my only problem is what to do with the cables when it is down.
    I don't want a hole in the ceiling to push the cables into, this would look even more unsightly than the mounting bracket!!
    cheers
    Josh
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    i mean have a cover, something like a double gang back box with a flush cover to hide the cables.
  6. S L KING
    S L KING
    Nov 12, 2002
    28
    What about setting the projector on a coffee table and hide everything when not in use. That way you won't have problem with the cables, but you do have to realign it everytime.
  7. Josh_P
    Josh_P
    Yeah Thanks S L King
    Not to helpful but thanks.
  8. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    You could always have some sort of fake light fitting (uplighter style) which could hide the cables when not in use.
    But I echo the others here and say leave it up all the time!
  9. S L KING
    S L KING
    Nov 12, 2002
    28
    I think people who ceiling mounted their projectors do leave them up all the time. It's the beauty of being able to switch it on and watch the movie without having to set it up everytime. There's the risk of dropping the projector(big one) by taking the projector down frequently.
  10. Parmenion
    Parmenion
    Feb 6, 2002
    1,171
    Out there
    +28
    Tell whoever is smoking to stop. They will then live longer and not end up dying in agony from cancer.
    You can then all spend much longer watching your lovely projector
  11. Josh_P
    Josh_P
    Yeah, thanks guys, all the advice except the advice I was looking for!! LOL
    Lots of advice on whether I leave the projector up full time or not.
    Let me put the question another way, does everyone who has a ceiling mounted projector, mounted perminantly or not, just cut a hole in their ceiling to let the cables dangle though or do some of you put in socket outlets and connect your projectors via short cable runs from outlets to projector?
    If you do just cut a hole for the cables, what do you use in order to leave a neat finish around them?
    Regards
    Josh
  12. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    I've just cut a hole, and the mount covers it :
    http://homepage.ntlworld.com/warren.alexander/ht/IMG_1691.html
    I used one of those funky circular bladed drill bits to cut the hole, so it's very neat.
  13. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    So what are these then??
    BTW You are lucky having a fairly modern home. I wish i could do that with my screen
  14. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    It's a drill bit with a saw blade mounted around it...if you imaging bending a saw blade in a circle.......I got it at B&Q. About 7 quid if I recall....
    Not that new - it's about 25 years old :)
  15. petrolhead
    petrolhead
    Mar 29, 2002
    4,497
    71
    Newcastle
    +83
    Doooooh yes of course.
    25 years old is new. My house is 1930's and latt walls, ceiling and some brick partition walls. Very sturdy but not AV friendly :)
  16. Woz!
    Woz!
    Oct 27, 2003
    107
    16
    Bracknell
    I bet it's more soundproof than some though :D
