Ceiling Mount
CinemaGuy
Established Member
I was wondering is there any ceiling mount were the projector is easily removed from its mount??? a ceiling mount which is at quite a cheap price and very close to the ceiling.
CinemaGuy
Established Member
Hi, thanks for the replies. Sorry i should have mentiond the projector model. It is an Acer P1165 DLP projector. Here is an image with the mounting holes dimensions and where they lay on the bottom of the projector.
ah132
I've used the following Vogels universal mount -
EPC 6545
Very impressed with it, neat design, solid and fully adjustable. Also, you can simply rotate the lock and remove the projector and cover the remaining mount + wires with the white dome cover when not in use.
Found it for about £75.
A
Rocky 4K, Creed 3 and boxing movies, Shazam 2, 65 trumping Jurassic World Dominion, + Picard & Mando
