Ceiling mount noise
Discussion in 'Projectors, Screens & Video Processors' started by Jeff, Apr 11, 2003.
Thread Status:
Not open for further replies.
  1. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    While watching movies, the ceiling mount for my CRT projector crack, creaks or tings every few minutes. Its quite loud and quite off puttung. Is this normal or should I get it looked into?
  2. Anders_UK
    Anders_UK
    Is it made out of metal?? If so it will be the material expanding with the heat exhausted from the CRT
  3. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Yes its a big metal tray like mount, is there anything I do can about it?
    Thanks,
    Jeff
  4. Anders_UK
    Anders_UK
    Try put some lagging around it, to stop the heat bulid up, this will also deaden the sound if it still does creak. Or even divert the hot air from the CRT with a re-directed bit of pipe or something.
  5. fatrich
    fatrich
    Jun 21, 2001
    2,403
    halifax
    +29
    Jeff
    is it a proper Barco bracket? if it is my bracket is a barco one and it and does creek especially when the pj has been on for a bit.
    cant suggest what to do though
    regards
    richard
  6. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    Hi Richard,
    Not sure what it is, Roland put it up. I might have a play at the W/E to see if I can deaden the sound a bit.
  7. Chris Frost
    Chris Frost
    Jul 14, 2000
    2,755
    Cheshire
    +108
    ...like a bell? Try Dynamat. Its a panel deadening material used in car stereo installations. You can cut it to shape and the back is self adhesive. Halfords sell it. You'll find Dynamat with all the speaker cable and poweramp accessories.
    Regards
  8. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    It's a feature of the 1209 I'm afraid they all do it. great when you are setting undernieth. should only do whilst it is warming up though. there are two metal plates in the projector clamped either side of the plasic casing
    Jeff tubes still oozing when warm I'm afraid.
  9. rigman
    rigman
    Dec 14, 2000
    2,760
    83
    East Yorkshire
    +59
    My 808s also cracks now and then. I have the plate mount. I thought it was a problem with one of my speakers when I first heard it and was about to jump up and start pulling things to bits. My wife told me what it was as she had tracked it down to the projector when I was working away.
    Darren
Thread Status:
