ceiling mount for Z3??
Discussion in 'Projectors, Screens & Video Processors' started by p.booth, Sep 19, 2005.
  1. p.booth
    p.booth
    Oct 8, 2002
    3,843
    mbro
    +126
    If I manage to get aZ3 (still procrastenating) :rolleyes: which ceiling mount would you suggest I use //
  2. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,097
    Shrewsbury, UK
    +266
  3. cooleo_no1
    cooleo_no1
    Jul 14, 2005
    116
    19
    Anybody got any other suggestions, that one looks a bit... well, flimsey.
    Oh and I don't like ebay... sorry.
  4. neil c
    neil c
    Mar 25, 2005
    537
    +3
    I use the Vogels EPC 4010 from AVRabbit - its by far the best looking ceiling mount available, all the rest look like meccano if you ask me.
  5. p.booth
    p.booth
    Oct 8, 2002
    3,843
    mbro
    +126
    Did you have to buy some m6 bolts and modify the boltholes or something Neil?? :confused:
  6. neil c
    neil c
    Mar 25, 2005
    537
    +3
    I got in touch with AVRabbit and I was sent some M4 to M6 adaptors (6mm or so lengths with M4 on the inside with M6 on the outside). They simply screwed into the M6 holes in the Z3 and then the M4 screws with the EPC4010 would fit as intended. Easy peasy. And suprisingly enough they arent too difficult to get out of the Z3 either.
  7. juniper
    juniper
    Dec 30, 2003
    1,808
    48
    +58
    Would thoroughly recommend LMP. Fantastic and robust product (IMHO), and lots of happy buyers on these forums. A search will help you with other opinions. I have one, great customer service, around £100 or so. :thumbsup:
  8. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,097
    Shrewsbury, UK
    +266
    The projector arrived first thing this morning and the mount works absolutely fine. Believe me when I say I have no worries that this cheap and cheerful little mount is well up to the task of holding the 4kg Z3 in place.
  9. p.booth
    p.booth
    Oct 8, 2002
    3,843
    mbro
    +126
    When did you order the mount Tyler??
  10. Tyler Durden
    Tyler Durden
    Apr 18, 2005
    5,097
    Shrewsbury, UK
    +266
    I had the mount from the projector that the Z3 has replaced.
  11. p.booth
    p.booth
    Oct 8, 2002
    3,843
    mbro
    +126
    Ahh I see!! :) I`ve ordered one and they say it`s been shipped so should have it in a few days yes.??
